thurmma
Went out Saturday to try and get a few flights on the 330LX, but the *@&$# DLE carb gave me crap again as I was getting ready for the 3rd flight. The plane ran great for the first two flights although I thought it was starting to sag a bit at the end of the second flight, and then when I was running it up on the ground for the 3rd flight, the top end was dropping off drastically so I shut it down and it was at 245 degrees just from a few seconds of running on the ground! GRRRRRRRR!!! I opened the high needle up to 2 1/2 turns and it wasn't sagging any more and temps were down so I put it in the air. After a couple minutes in the air it started getting really rich in the middle 2/3's of the throttle range. I know it was richer than snot because when I would roll it the engine would almost die from the unburned fuel getting sucked into the cylinders. I hope I can get a carb from DA by Thursday. I am sick and tired of fighting with this carb. The engine ran great for the first 3 to 4 gallons and then the carb issues started cropping up. I have already pulled the reed block and worked it over, so that isn't the issue. Switched fuel tanks from dual 32oz to a single 50oz, so that isn't the issue either. The only thing left is the carb
