Bluepilot2003
After conversing with Colton at DA, I will be getting a new set in the mail as he also thinks they are for the DA-100. Kudos on the awesome customer support!
Batteries for my buddies MXSR finally got here. He ordered some too and the race to see who's order got here first was a tie
. Actually he won because he called me and told me he had just got his as the FedEx truck was pulling into my drive way
. He got the plane back over to my shop and we went to work getting XT60's installed on the batteries then tucked them in their bed on the plane. Of course I remembered to charge em up this time
. So what actually happened here was validating a good cg point (plane was very nose heavy when I gutted it to do a new install). Then we went off to the field and all I can say is Charlie is one happy camper with his MXSR now
I did get a little something for me too with them "other batteries" that will be a nice addition to my shop tools and utilities......
Should come in quite handy when installing the BLS H50B servos in my next plane.
View attachment 98401 View attachment 98402
Ok what is it and what can you do with it ??????. Cannot read the picture.
I need to do this to my sukhoi. Down thrust is fine but it as well has a strong pull to the left in an upline. I did a rudder to throttle mix but to get it to go away I have I think almost 15% rudder input at full throttle which I feel is a bit excessive.I made a shim to add 1 degree of right thrust to my Hangar 9 Extra 300X. I've already added 1 degree of down. I'm not sure 1 degree right will be enough, but it's all I could get out of the plastic shim I had. Hopefully this will help the pull to the left in a vertical line.
I've also noticed the pull to the left in things like the amount of rudder it takes to do a right rudder knife edge as apposed to left, and the nose pulling to it's left when going from inverted to the third point in a four point roll. Holding a straight line is harder than it should be.I need to do this to my sukhoi. Down thrust is fine but it as well has a strong pull to the left in an upline. I did a rudder to throttle mix but to get it to go away I have I think almost 15% rudder input at full throttle which I feel is a bit excessive.
After about 4 years and 11-12 gallons with my 71" slick I think my plug cap is worn out on the DLE35. Pretty dirty inside and the spring and rubber cap seem compromised. I put it back together along with a new fuel tank and it will only run at idle for a short amount of time. It could be my new pickup clunk... I blew some air into the tank through the vent line and it had to build up a fair amount of pressure before fuel came out the detached outlet line to to carb. Curious if these flow master clunks are not very efficient?
Top is the flowmaster from eflight
Middle is the fortitude I had previously
Bottom is a TDRC which isn't filtered. I believe.
Wanted a felt version so I put the flowmaster in a TDRC tank with viton line.
Ordered a new cap and ignition.
Might try and do a pressure test with the different clunks to see if there is a noticeable difference.
