OK, so here is a dumb question. I'm thinking of trying a couple of LiPo's but I need to put a regulator in my plane because I'm not going to rush out right now and buy new servos for 8 GS planes. I will have to slowly switch over. I am looking at two regulators from two different companies that I can regulate to 6.6 volts. One of the regs also has internal battery matching and isolation features.
- So my question is, has anyone heard of any issues with a Spektrum power safe RX that is fed by a regulator that also has power safe features??
My simple way of thinking is the answer is no, because the RX should not care less how it is being fed.
To some extent Terry, you are correct. Most all rx's don't care "HOW" they are fed. But the biggest thing to remember, is to allow for a constant "UN-INTERRUPTED" power supply for the rx. I have read and seen some systems set up in such a way that servos were drawing power through the rx. and thus high demand from HV servos have been reported as drawing so much, that the rx itself "starves" for voltage. Dropping below the nominal 3.3 or so volts, causing brown out and complete loss failures. I know a lot of you out there don't use the SF boards, a lot of you have power safe rx. that allow battery redundancy. But the biggest reason I have used and continue to use the SF boards is because the SF powers up the rx to a constant 5 volts. With absolutely no risk of losing voltage, (unless the batteries are drained) And also allows battery redundancy for the rx. as well. While supplying a direct supplied voltage to each servo. Pluse with the SF boards, you also have internal battery matching and isolation features. As for using a regulator to utilize two lipos is a sound idea. Fromeco and SF both have some awesome regs. I have used both in the past. I think I like the Sahara from Fromeco best. I don't know Spektrum, but I would say if you are using a power safe version, You're covered except for the servos. You would need to find a way to regulate the servos to the 6.6 volts you are looking for. If you regulate the entire system, such as two regs, one to each battery connection on the power safe rx, then you are covered completely. And since you are not using HV serovs, you most definitely are not going to be starving the rx. for needed voltage. Unless you are considering a single reg that will give you the battery redundancy along with the battery matching and isolation features. Then in that case, You're set!!
I truly am a "HUGE" advocate of the SF boards. Battery redundancy, constant un-interrupted 5.0 volts to the rx., and battery redundancy of battery supplied voltage to my servos. If I were using a normal voltage servo system, I would go the route you are thinking.
These are just my thoughts. Maybe someone knows of a better way?
