60" Laser-EXP
3dbandit
I have had many digitals do that. I just put a small piece of the fussy side of velcro in between the balance tab and the stab and that fixes it. Very common problem and very common solution.
These not only shake when centered, they twitch at all deflections.
BTW, I am up to 4 failed servos of the 5 Spektrum 5060's that I have purchased.
3dbandit
Almost done, just waiting on replacement servo's from horizon... :)
wedoitall
Member
that's whats going in mine. eventho I may switch out to the ones Cody is using after ive seen that they can hold up
Ohio AV8TOR
Just Do It
I used 7245's on my Edge on 8.2v and they are awesome and now putting them in my Laser. They have some twitch in the neutral position at times but a little flick of the gimbal and it usually stops. They are fast and really helps with rolling circles.
YellowJacketsRC
I have been using 7245s for the MXS and the Edge. They have performed flawlessly for me with the exception of some jitters around neutral at times. But I use fussy velcro as a matter of course and all is well.
