Made a flat edge on several spruce dowel wing tips.
Bouncing around today. Cut a trial wing strut in aluminum but not sure it's strong enough.
Will these struts bear a side or up/down load? Or will it be end load? Reason I ask is if they will be bearing load from end to end, they should be just fine. Side load or otherwise could allow them to bend. But you knew that huh? LOL
Cute little clamps I found at Home Depot today. Already using them.
View attachment 102420 View attachment 102420
I have a couple of clamps like these. Not the quality brand name as yours, but work just fine. I don't know where I would be without them.
I will cut them in Steel versus aluminum.
