I must say Mr. Snoops, your building capabilities are quite nice. Clean and orderly. Just a little worried though. Have you ever heard that a clean desk is the sign of a sick mind? You are one sick puppy. LOL. Keep up the awesomeness.
Will not deny it for minuet any body that spends this amount of time build a plane that can be gone in a second is a sick puppy and then on top that will do it again.
Go for the left wing first while the lessons learned from the right one are fresh in your mind.
And as @stangflyer said, very clean build and clean shop. Mikey like. :big_yes:
Yes I think you are correct will be easier to remember what I did.
Did you mention about a carbon spar or rod for the ailerons if it is can you elaborate how you did it. Thanks.
One question how many oz-inch servo would gentlemen put on 120cc Extra RUDDER for good 3D performance and speed.
Got the second wing on the bench and yes it went a lot quicker now that I know what to watch for. Did a lot of sanding on the support shear web that runs the length of the wing. Top spare is epoxied in now just leave it alone for 6 hours and then I can continue.
