The tractor was needed the barn is be built from true 2 by 6 Douglas fur, and it is much heavier than spruce we could not lift the walls in place so a tractor was purchased to help lift the walls in place.
A half inch gap won't let air circulate so make sure the insulation is a full 6" or it will get condensation between it and the exterior covering.
We are going to use Roxcell insulation and it will be packed in tight in between the 2 by 6 studs and the 2 inches of hard Roxcell will be attached to the outer side structure and then wrapped with a special vapour barrier and then all the seams sealed with Tuck tape.. and finally the metal siding.
That sounds like it gets cold up there.......
The new pavilion at the field is almost done. Just a ridge cap and some gable end trim left.
They also started prepping for the new Geotex on the North South side runway. So we'll have Geotex on the East West and North South.
Spent some time in the shop and worked on the 3W engine. Well after some careful planing and some precise work managed to get a nice bead of RTV around the Reed holder and not get any of it on the reeds. Now it has to cure for 24 hours and then the reassemble the engine. Then mount it on the test stand and see if it runs properly.
