Discussion in 'Giant / Scale RC General Discussions' started by Xpress, Sep 13, 2014.
  1. Snoopy1
    Snoopy1 640cc Uber Pimp
    6,056
    8,296
    113
    Canada
    The tractor was needed the barn is be built from true 2 by 6 Douglas fur, and it is much heavier than spruce we could not lift the walls in place so a tractor was purchased to help lift the walls in place.
    AKNick, dhal22, WMcNabb and 1 other person like this.
  2. WMcNabb
    WMcNabb 150cc
    1,520
    3,159
    113
    TN, USA
    That’s the best excuse I’ve ever heard to purchase a tractor :)
    dhal22, Snoopy1 and pawnshopmike like this.
  3. acerc
    acerc 640cc Uber Pimp
    2,912
    4,589
    113
    Florida
    A half inch gap won't let air circulate so make sure the insulation is a full 6" or it will get condensation between it and the exterior covering.
    Snoopy1 likes this.
  4. Snoopy1
    6,056
    8,296
    113
    Canada
    We are going to use Roxcell insulation and it will be packed in tight in between the 2 by 6 studs and the 2 inches of hard Roxcell will be attached to the outer side structure and then wrapped with a special vapour barrier and then all the seams sealed with Tuck tape.. and finally the metal siding.
    AKNick and pawnshopmike like this.
  5. dhal22
    dhal22 GSN Sponsor Tier 1
    That sounds like it gets cold up there.......
    pawnshopmike likes this.
  6. Snoopy1
    6,056
    8,296
    113
    Canada
    You got that right and it makes for a long building season and we would like to be comfortably.
  7. Jetpainter
    Jetpainter 640cc Uber Pimp
    The new pavilion at the field is almost done. Just a ridge cap and some gable end trim left.
    They also started prepping for the new Geotex on the North South side runway. So we'll have Geotex on the East West and North South.
  8. AKNick
    AKNick 150cc
    2,310
    3,732
    113
    Alaska
    Man, you guys are out doing me! Love the pavilion @Jetpainter and that airplane shop @Snoopy1 !!! I need to build a shed to store all my other stuff that shouldn't be in the house! Maybe this winter I'll sketch up some designs for this summer/spring. You guys are an inspiration!
    Jetpainter, Snoopy1 and pawnshopmike like this.
  9. Snoopy1
    6,056
    8,296
    113
    Canada
    Spent some time in the shop and worked on the 3W engine. Well after some careful planing and some precise work managed to get a nice bead of RTV around the Reed holder and not get any of it on the reeds. Now it has to cure for 24 hours and then the reassemble the engine. Then mount it on the test stand and see if it runs properly.
  10. BalsaDust
    BalsaDust Moderator
    stacking all the lumber I got yesterday when the portable sawmill made its way to my house to mill up the logs I have from the trees I cut down. IMG_7650.JPG IMG_7651.JPG IMG_7652.JPG IMG_7653.JPG IMG_7654.JPG
    dhal22, Luchnia, WMcNabb and 4 others like this.
