Before gluing in the phenolics now is a great time to double check the fit of the foam to the fuse. Cut the phenolic cleanly and neatly so that it sticks out of the wing about 3/32" or slightly less. Slide the root rib onto the phenolic and slide onto the plane. Adjust the root of the foam as needed for a perfect fit, it should be extremely close.
