3Dchief
Not exactly an airplane or RC related, but built this boot shelf for a friend of mine. She found a similar one online and wanted one, but couldn't find one to buy anywhere. Got the old horseshoes from a local rancher and had the lumber laying around, so the total cost was under $20 and about 6 hours of my time. Hardest part was cleaning up the rusty horseshoes with a wire wheel, that took hours! My favorite kind of project, combined welding and woodworking all in one!
sweetpea
I finally got the contract for my new 24x30 bldg! Too bad I still have 6in of snow on the ground, but it should be gone in a couple weeks, about the same time my permits are approved.
There is supposed to be 8-12" of snow falling tonight at my place. Glad I don't have to be back at work until Friday night. Time to get in the shop and start building.
sweetpea
Oh, then I still have to put in concrete, insulation, electricity, a good floor etc etc etc.....its going to be a while :(
HornetNZ
Landing gear & pants mounted. Flying wires done. Almost done!
Learned a new trick for pull-pull/flying wires. If using nylon coated wire, loop it thru, twist it a few times and hold a lighter under it. The nylon melts and fuses together. Then you just put heat-shrink over it. Jesky said he's done that for a long time and it's never slipped. Heck of a lot easier & faster than using crimps!
Finally rebuilt my sbach45 after its dreadful mainden flight. Just need to make up extensions for the new tail servos, install the tank, and get a new pressure tap for the header (I kinda sorta broke the other one installing it in the new header).
yakken
I'm in the dinwiddie county. Just south of petersburg and colonial Hieghts. If you look up Richard bland college I'm not far from it.
Me and my brother host a giant scale 3d event in gerrardstown wv. We will be having it in sept. Come on up and throw down.
