IMAC Terryscustom 35% MXS-ST Prototype
Thanks everyone for joining in!
I got a little more done this morning but now I need to pay the bills for a few hours before I can get back to it. Fuse sides are installed and fuse top is test fit. I don't think I can say it enough, TEST FITTING is very important before gluing every part! Also want to point out (maybe brad a bit) that I have not used a flat table. When assembled as I show the fuse is perfectly square and straight, or if you are the super engineering type that measures down to the thousandths.......it is more straight than pretty much any ARF.
I really sucks when having to work gets in the way of your hobby. I was just on the phone with a friend discussing this very thing and we decided men of our caliber shouldn't have to work for a living.;)
And, I have no doubt your airplane will be straighter than an ARF. Looks awesome.
Rick at @Fibertech is working on fine tuning the foam for the MXS-ST. He does simply amazing work with top notch quality:yesss:
mikeh
Damn Terry, you are a machine! I've never seen an airplane go together so quickly. Great work!
Alrighty, work is done and gone......back to the fun stuff!!!
Wrapping up the rest of the fuse parts, a little tri-stock to support the fuse bottom by the tank, RX and battery tray and front. Install landing gear and bottom vents. Epoxy in landing gear aluminum brackets. Install X-brace in top of fuse.
