3D 20cc Giles 202 Profile
Yeah they go fast for me at least. See a few things that need to be changed on the plans and on the plane. Not enough clearance for the elevator.
Have a question have ever given it any thought of making the slab fuselage out styrofoam sheet and then sheeting it.
I did this one that way. Thought about it on this but I decided against it. The way I fly on 20cc and smaller I fly them hard and dork them a lot. A built up fuse with a tube is easy to repair after a dork where as the foam fuse will not be.
Pretty much a guarantee that anything 30cc and larger though that I build as a slab will get a foam fuse.
I can link my probro build thread for the big edge if you would like to look at it.
View attachment 98869 I did this one that way. Thought about it on this but I decided against it. The way I fly on 20cc and smaller I fly them hard and dork them a lot. A built up fuse with a tube is easy to repair after a dork where as the foam fuse will not be.
Man that does look good, must say those are my favourite colours. That is a 30cc done with foam. Like that. Where can I find the ProBro build would like to read through it thanks.
A 35cc would pull this plane fine but I actually have a dle55 on the nose. Weighs 13.5lbs with the 55. I need to make a couple changes to the plane but it performs great. There are videos in this thread here. Also it's not much of a build thread but it shows the basics.
http://www.theprofilebrotherhood.com/forum/viewtopic.php?f=20&t=39222&hilit=Big+tiddy
