Thanks all, I really do appreciate all the kind words!
So bad news is, for the first time ever FreeKote mold release has let me down. The plug stuck in the mold in a spot around the front ring. #@%^!%@$$#^!!!!!!
Good news, the plug only got screwed up on the side where it stuck, the other side just has a couple of dents. The mold itself is just fine. After getting the plug out a couple of minutes of scraping with a credit card blank and doing some wet sanding it will be just fine. Had to patch a couple of air bubble spots but it will get the job done.
Where the plug stuck, all of the other marks and dents and dings are from screwdrivers, paint sticks, putty knives ect trying to get the mold off. Luckily we got it done with only 2 dents to the plug on the other side of the part line, so I should be able to get the mold finished.
After a little bit of scrubbing the mold looks fine. A few air bubble pockets need to be patched but nothing drastic. It should make a good part.
I cut up some scrap luan I had to add a stiffener to the outside of the mold, I bonded it to the mold with resin and thixotropic silica after tacking it in place with CA. This made a rather flimsy mold rock solid and should help keep it from warping due to the shrinkage of the poly-ester resin.
After I patched the air bubble pockets with some resin and thixotropic silica.
For anyone that is curious, thixotropic silica is a resin thickening agent that helps make a strong and hard gel. It's really good for building up tight corners were cloth won't lay and making a brush able gel coat. Most important thing about mixing thixo into resin is to use enough. when you first mix in some of the powder it will look clumpy in the resin, you need to keep adding thixo until the silica particles are close enough together to tear at each other, spreading out the resin over the silica. You will know that has happened when the mixture looks like a peanut butter type consistency without any lumps of little white balls of silica.
