3DHS --FLY LOW-- Always OFF TOPIC
wedoitall
Member
I tested then thoroughly about a year ago. The ability to remain cool and perform at high power levels exceeds the life of the bearings. If you stay on top of the bearings, (ie, change them periodically, or replace with premium) then the motors will last forever.
approximately how many flights should i replace them? probably would be better just to get some boca's, acer's, some better bearings and install them before i even run it? after i toasted the Omega i read manuveurs like the KE spin are hard on the bearings of a motor. wish i would have read that a couple days sooner :D
say even on a motorfly, after how many flights should i check out the bearings?
3DHS --FLY LOW-- Always OFF TOPIC thread
For hard abuse, I'd replace them right off the bat. I've even had to replace my motrolfly bearings... No engine is immune to my abuse of KE spins, blenders and crankshafts!
Usually with the motrolfly, you can hear them starting to rub and grind a little before total failure.
quadracer
I've got roughly 50 flights on my 4315 in the 57 Extra (the KE spin being one of my favorite maneuvers), and it still turns smooth as silk. I'd say just give the prop a spin by hand every time you take the plane out, and if it starts feeling gritty or not as smooth as it normally did, order a new set of bearings. That's the method I'm using on mine, others may have a different opinion.
That's what I do with my motrolflys
Feral
Member
Do boca do bearings for the EF and motrolflys? That make some real smooth heli bearings
wedoitall
Member
yea they make them for just about everything. i like acer and avid bearing also. just havent check them out for planes yet.
