robj
I have a HPP -25 I just used for the first time on the 103. While it was a chore(I helped Bivens on his 104 using his jr 12x and it was easier). But I got the hang of it, did need a third hand for the Tx. I noticed the slight difference between the programmer and Tx. I logged every move I made and in the end would adjust the servo using the programmer by 1 or 2us. Eventually got it good. It was useful on one wing I had the servo maxed out and still needed more. So I programmed the other servo for slightly less travel in that direction. Worked! These endpoints were a lot higher than what I will fly with.
I just did the elevators yesterday(copied the 87 program and maxed out everything, used ele/aux2) and got everything spot on with the linkage, endpoints all good at first look. Getting about 50+ degrees. . I almost picked up a used 11x to avoid this on the wings. But I think the 11x can only handle 2 servos per wing and eventually I'll want to go 3 servos.
