I have been making a little progress lately. I mounted the ignition, built the tank, made a mount for the Powerbox kill switch, installed the LED for the kill switch and roughly laid out most of the wiring.
I ended up just strapping the ignition to the front of the firewall, because there just wasn't any good way to do it. I wanted to mount it on top, but the plug lead is to short. I built a nice ply mount to attach to the front of the firewall, but I couldn't use it because it made the ignition box block access to the carb needles. So, it's strapped to the front.
Yesterday I starred at it for an hour trying to figure out where the vent line was going to go. Boxing in the pipe tunnel blocked all access to the bottom of the fuselage. I finally decided it had to go out the engine box, but it needed to be clear of the battery mount. It took some thought, but I'm happy with the results. I still need to glue the tubing in so it won't move around.
I also decided to mount the fuel dot inside the hatch so I made a ply bracket for that. I haven't glued the bracket in yet, but I think it's going where I have it in the pictures.
The wiring still needs lots of tidying up, plus I'm still waiting for my receiver mount.
You'll notice that the tank has both Viton and Tygon in it. The Viton was all I had, and if the short piece of Tygon gets hard it won't hurt a thing.
