Thanks guys! That is where the Jetpainter name came from. I used to paint, or build and paint airplanes for people many years ago, mostly ducted fan and turbine jets .
Here's another way to eliminate the spitting in the box. It's a piece of PVC pipe. I used a scope extension ring to secure the screen on top. Not really needed tho. Pics will tell the tale.
View attachment 93075 View attachment 93076
View attachment 93074 View attachment 93073
That's pretty cool, I thought about doing that. I would need to go out the top like you did, but I think I'm going to need that real-estate for other things.Here's another way to eliminate the spitting in the box. It's a piece of PVC pipe. I used a scope extension ring to secure the screen on top. Not really needed tho. Pics will tell the tale.
That is realy nicely done hope to copy that in the near future. It will not work on the plane I am presently working on but soon. Thanks for that idea.Here's another way to eliminate the spitting in the box. It's a piece of PVC pipe. I used a scope extension ring to secure the screen on top. Not really needed tho. Pics will tell the tale.
That should do the job and it looks clean and neat.I ended up enlarging the hole I had in the firewall by dropping it down and squaring off the bottom edge. Then I made a box out of 1/32" ply, fuel proofed it and glue it on. I also put an angle on the bottom of the hole in the firewall so anything that collects in the box will drain out.
View attachment 93123 View attachment 93124 View attachment 93125 View attachment 93128
Hah...yeah, at the time I needed a longer arm and didn't have one handy so bolted the longer one (that wasn't the correct spline size) to the smaller star-shaped one.That is realy nicely done hope to copy that in the near future. It will not work on the plane I am presently working on but soon. Thanks for that idea.
Can you explain your throttle servo arm it does not look right ? Is there two one on top of the other.
