AKNick
AJ 73" Laser 230z
Horizontal Installation:
I used some lacing chord, tied a loop on either end, went from the inboard side of the wing tube to the outboard tip of the horizontal, and matched the other side as best I could. I double checked the fit with a ruler by laying it across the leading edge. Then I drew a line with a pencil and lightly scuffed the covering in between the lines I just drew. After that I basically slid the horizontal back in to where those lines were, double checked the measurements, and wicked some thin CA in slowly. Be careful you don't let it run down the bottom. Flip it over and wick it in again. I actually repeat this process 2-3 times. What can I say... I'm an "overachiever".
