Futaba 18MZ/14SG/8FG Tips and Tricks
Jlc
Ok I think you are missing a step because I did the same thing when I set mine up. The telemetry didn't work until the numbers appeared. I will go get my notes and get back to you.
@Mikeq got me there! My 14SG now displays the receiver voltage. I said it was something simple. lol
From the link menu select system. From the system screen select/highlight "link". Tx will tone for about 4 seconds in which you then simply turn on the receiver and Yay! It works! Receiver ID stored and voltage is now displayed on the monitor along with link strength.
garlandk
Here is my dual rx setup. RX 1 is Channels 1-8 RX 2 is Channels 9-16. Just had to change the RX mode then link both RXs. Very easy to do!
Ohio AV8TOR
Just Do It
Kevin how did you mask the covering around the stringers when you painted the inside. I always paint that texture on all of my firewalls but never do the inside as it seems like a masking nightmare.
3D-Joy
If it was me, I would paint BEFORE covering.
