Last night I started on several more test panels. This time with lightweight glass cloth. I weighed them carefully with a paint scale before glassing and used hair spray on some. This time I should be able to tell if the hair spray panels use less resin of not. I'll sand and weigh them tonight and see.
Last night before leaving work I sprayed two of the original panels with epoxy primer. Today I sanded and weighed them.
Panel #1:
Weight after cloth and 1 coat of resin, sanded. 0.29 ounces
Weight after 2nd coat of resin, sanded. 0.29 ounces
Weight after 1 coat of joint compound, sanded. 0.29 ounces
weight after 2 coats of Nason epoxy primer, sanded 0.30 ounces
The technique used on this panel in my opinion is the best of the ones I've done. It gained the least weight from glass to ready to paint and I don't think it will have any shrinkage down the road.
Panel #2:
Weight after cloth and 1 coat of resin, sanded. 0.27 ounces
Weight after 1st coat of joint compound, sanded 0.29 ounces
Weight after 2nd coat of joint compound, sanded 0.29 ounces
Weight after 2 coats of Nason epoxy primer, sanded 0.31 ounces
Though this panel turned out well it gained more weight than others techniques. Also it showed a lot of areas in the primer that has soaked into the joint compound. It sanded out well, but I would have concerns with shrinkage out in the hot sun.
The panel on the left is the one that the primer soaked into the joint compound. The right one was nice and smooth.
