3D PAU 100cc EXTRA 300sp
Islandflyer
AEROSHELDON;20010 wrote: HMMM. I got mine used and did not build it, but I did not see that in the manual I downloaded. I do have a V1 plane though.
Thanks for the info!
All versions should have it; we recommend two servos if you use push-pull: if only one is used, given the high speed and torque of current servos, it can damage the hinges from the "pushing" action.
3dbandit
I should have mentioned this; I am using slightly larger than stock Robart Hinge-points on the rudder to prevent hinge damage.
3dbandit
         I finished running all the wires to the rx.
          Wheel Pants mounted. I placed a one inch book under the rear of the pants to give the right distance from the ground
Pictures are uploading weird
Dan767
I've finally had a chance to maiden my PAU Extra300. 3W-110 on KS 86 cans for power with a 26X12N three blade Mejzlik. Futaba sbus servos. I'll be able to get some pictures and post them later. My CG is just a little bit forward for my liking (just on the forward part of the wing tube). It was a blast to maiden the airplane and I'm impressed with the way it fly's.
Tseres
My CG ended up about 3/4 to the back of the tube. Almost nutral there.
3dbandit
I'll be sure to have videos once I have the plane flying.
Almost there...
Here's whats left: throttle servo and linkage, cut and baffle cowl, install ignition system,  install fuel system, CG.
