Bunky.F.Knuckle
2 more flights tonite. Solid as a rock!
Aren't you supposed to do that every single flight every single time your at the field? We have guys in our club that do.3 more today. Need to commence twisty thingie twistin...
I'm tickled pink that your 120 runs just as well as Chad's and Diggy's, Rob. Mine, not so much. I think I was more amped up about this engine than you were.
Not sure on mine, but 3 mins into the first flight, she locked up tighter than a snare drum. Not hard on it, did 1 vertical pull at full power and 1 short downwind blast, just after take off. Idled great, transition great, no burble, high end sounded awesome. It did try to take my hand off 2x, but fortunately, I flip hard and fast. Almost sounds like some preignition is happening.
Oh well. It happens to the best of them anytime, any place and any engine. No collateral damage, so that is the nice part. It will be a few weeks before I get the engine out and back.
Mate has one and his lasted 2min max . Was hard to start and bit 3 hands . Then they found only one cylinder firing . Swapped ignition and plugs then it ran for 2mins . Seamed like a bearing let go . Shrapnel inside destroyed both pistons. New engine on its way . His mate has one and no problems. Ive yet to fire mine up . Found prop shaft is not parallel and thicker at the tip just as you start to put prop on . The exhaust bolts are too short to use and so are the prop bolts . Will also replace spark plugs before starting . Hopefully I have a good engine .
