3dNater
[MENTION=3822]Xpress[/MENTION] I'm guessing you are running into a caching issue at the DNS server level. It should update and clear up in time.
Here is something you can try also. I just found it in one of the RCG threads. You are not the only one having this issue.
-If they have the website on a new server your pic might not have latest DNS addressing. Open command prompt (in accessories) and run "ipconfig /flushdns"
One user there reports that this fixed their issue.
Bloosee
Cleared both out, but not cigar.
Coincidentally I was trying to get to the EF website last night for a customer service issue and it would not let me in, (I did not even know they had the new site). Tried all the possible paths in but it wouldn't work. This morning it worked for some reason.
Xpress
I know it'll go away, but for now it doesn't seem to be working at work, being a company computer I'm not going to mess with anything.
I'll try it at home, Windows 10 just installed so I have to play with that anyways ;)
EDIT: CTRL + F5 worked, can view the new site no problem now.
Xpress
Lower?
wfahey415
3DRCF Moderator
I still see daylight.... :flyer: Nice job Xpress.
Had a guy at the field do a low flyby with a 35cc P-51. Actually hit the prop on the ground and splintered it. He was able to pitch up, drop the gear and still land it on the runway with the engine running. If it had been me, I would probably have a garbage bag full of P-51 pieces.
