New Product Twisted Hobbys- Official REVO P3 build and review thread
Decal Dennis
TEAM EP&G
Glue the lower half of the vertical fuse in place, make sure it is 90 degrees to the horizontal fuse
Decal Dennis
TEAM EP&G
Install right side beveled brace, I used thin CA. Use the full length on this side
Left side beveled brace, full length not used. Note length in pic, doesn't need to be exact.
Decal Dennis
TEAM EP&G
Control horns: The top 2 are for the ailerons, the bottom left is for the elevator, bottom right is for the rudder. (strut shown for contrast only)
Elevator horn
Rudder horn. I like to lightly score the horns so the glue has more to grab onto.
Glue the elevator and rudder control horns in place. Rudder horn faces to the left of rudder, elevator horn on top.
Decal Dennis
TEAM EP&G
Elevator push rod components. Ok here is where I almost messed up!! I wasn't paying attention and used one the threaded aileron connectors on the smaller carbon push rods. I figured it out pretty quick and was able to save it. Threaded connector pictured here is for the aileron connecting rods. E1-E5 stand offs are for the elevator, the unmarked ones are for the rudder.
Again, threaded connector pictured is the wrong one for the elevator.
Stand offs glued in place, I use foam-tac so there is no chance of CA wicking up and gluing the carbon rod to the stand offs.
Rudder push rod components. Correct threaded connector shown
For reference: the top longer threaded connector is for the aileron connector rods
Decal Dennis
TEAM EP&G
After you have glued the top and bottom, left and right wing halves together, cut a slot for the 4 long 1.5mm carbon rods in the top and bottom of each of the wings(top and bottom wings) Top of the bottom wing shown here
Bottom of the bottom wing shown here
Bottom of the top wing shown here
