New Product Twisted Hobbys- Official REVO P3 build and review thread
Decal Dennis
TEAM EP&G
Cut slots for the aileron servo ears
Cut a slot just behind the carbon spar to tuck the servo wire into. Servo to fuse.
Servos centered and arms installed. Hot glue servos and servo wires in place
Decal Dennis
TEAM EP&G
Horizontal tape is hinge line reference, line up control horn hole on this reference. repeat for left and right.
Mark cut line and start and stop of cut line
Make cut, remove tape and glue horn in place.
Cut the heads off 2 of the M2x16 screws. There is a total of 4
Aileron push rod components
Approximate measurement, yours may vary slightly
Finished assembly, make for left and right
Decal Dennis
TEAM EP&G
Note that wing strut tabs are different sizes to fit in the top and bottom wing correctly.
Glue in the wing struts, carbon faces the fuse
Top wing temporarily in place while the glue dries on the bottom wing, this will hold the struts in the correct position
Decal Dennis
TEAM EP&G
Drill a 5/64" hole for the axle screws
Getting the carbon gear through there is a bit tricky, make sure it stays in the skinny part of the slot as you are installing it. Note: you will be compressing and flexing the foam in between the phenolic plates to get the gear through, this is ok, just be careful and take your time.
Decal Dennis
TEAM EP&G
Install wheel with washer and nut, be sure and use a little bit of blue loctite. Snip the excess screw off, this will also help keep the nut from backing off.
Glue the outer wheel pant cover on, let the screw pierce into the foam a bit.
