Here is my current setup. When I had the other dle on there, it was using their supplied short phenolic arm which is why the linkage came out higher. The problem with that setup was that the choke and throttle would bind up on each other. I believe I can just cut a slot lower on the firewall and use the same location that you are for the servo.
