3dmike
Hey guys!  So here I will be documenting my half build.  What is a half build?  Well I bought a used airframe (6 or 7 flights on it) and will be building it up (New servos, New motor, New everything….) at least to the plane!
Here is the specs:
Here is the plan:
Motor: DLE-111 v3 (Thanks Donnie!)
Servos:
Rudder: Savox SB-2230SG (x1 rated at 6v 499.9oz @ .16 or 7.4v 583.3 @ .13 Weight(g): 84.0)
Elevators: Currently have Futaba S9157 (6v 425oz @ .14) but may switch out
Ailerons: Savox SC-1268SG (x4 rated at 6v 208.3 oz @.13 or 7.4v 347.2oz @.11 Weight(g): 62.0)
Throttle: Savox SV-0220MG (x1 standard HV servo 6v or 7.4)
Power Board: SmartFly EQ6
Batts: Fromeco Relion 2600
Prop: Not sure yet Maybe Falcon 27x9
Switches: Wolverine
Ignition Kill: Smartfly
Made some progress yesterday and today:
Mounted servos, engine and power board yesterday/today
Had to drill hole for the exhaust since [MENTION=2649]GOGO24[/MENTION] used the pro flow cans.
I will get some better pics soon. Since I don't have a work bench that i can pull the middle of the garage my back is killing me!
			Here is the specs:
- Wingspan: 106" (2.69m)
 - Wing Area: 2028 sq in (13084 sq cm)
 - Fuselage Length: 90 in (2.3m)
 - Weight: 27 lbs (12.24 kg)
 - Engine: 100-120cc
Here is the plan:
Servos:
Switches: Wolverine
