HRRC Flyer
Good evening Gents,
Since mother nature didn't let me fly today, I pulled my GP Giant Stick out to work on it and I ran into a little problem. I found my voltage regulator for the Evolution Ignition module I bought about six months ago. I also took the 1800mAh and the 2200mAh Hyperion batteries out that came with the plane and put in a single 3600mAh LiFe battery with two output leads. I found a place to secure the battery that was not under the fuel tank, thankfully and strapped it in. I plugged one of the battery outputs into the receiver, via one MPI switch. Then I turned the transmitter on, the receiver switch on and the servo's came to life. So I took the other battery output and plugged it into the voltage regulator. Took the output lead from the regulator, plugged it into one side of another MPI switch and took the lead coming back from the switch and plugged it into my RCExcel optical kill switch. I took the output from the kill switch and plugged it into the ignition module and plugged the kill switch into the receiver. No matter what I did next, I could not get power to the ignition module. I tried the second battery output in the receiver and it worked fine, so that wasn't it. I tried the second MPI switch in the receiver circuit and that worked fine too. I even plugged the regulator output into the receiver and the servos still worked. I am at a loss as to what I have wrong. Can someone help me out? . . . . .
Thanks,
Thanks,
