Please do, inquiring minds want to know!I did... I need to update the thread I guess. Crazy findings!
The weather forecast is for awesome today. Got my radio back from Hobby Services and ready to go. Both my trainees say they can't fly today. I guess i'll have to let some of the other guys find a way to make my heart skip a beat or two.
That is such a nasty spot it seems. A little trick I discovered is slicing laterally through the covering about an inch long. It helps release the gas pocket that occurs when ting to iron it back down. Then a tiny same colored covering patch strategically placed over the slice and wa-laa.The weather turned out less windy than expected today, so it was a great day at the field. I'm having to get used to the Pilot Edge all over again, it's like a different airplane with the GP61. I need to move the batteries back since it's a bit nose heavy now, but the added power is great. I was messing with rolling harriers today. I always had trouble keeping the nose up with the DA50 but now with some extra power it's quite a bit easier. I may actually learn something now!
There was a whole flock of EDF jets at the field today. One of the guys let me fly his Freewing F86. Not a fast airplane, but still a blast to fly. He also had a hopped up Habu that was pretty fast.
When I was getting ready for my third flight today on the Edge I noticed a spot of covering coming off the base on the vertical stab. That spot has always been bad and full of nasty wrinkles. A few weeks ago I noticed the seem separating when I was loading the truck to leave for the field so I put some clear packing tape over it. The spot that let go today was behind that. Since the show must go on, I asked around and one of the guys had some white electrical tape. Not my first choice for a field repair, but you've got to do what you've got to do.
View attachment 90196 View attachment 90197
The factory covering job was pretty good with the exception of that spot. No matter how bad my repair job comes out, I doubt I could make it look worse.That is such a nasty spot it seems. A little trick I discovered is slicing laterally through the covering about an inch long. It helps release the gas pocket that occurs when ting to iron it back down. Then a tiny same colored covering patch strategically placed over the slice and wa-laa.
Been there too. Just really sucks when you have such a nice covering job and one little spot just breaks your heart.The factory covering job was pretty good with the exception of that spot. No matter how bad my repair job comes out, I doubt I could make it look worse.![]()
