Well with the weather the way it is I got the urge to do some building. Got the Viper ST out and glued in all the horns for the plane. Can’t believe it, it took me most of the day but it is done and I enjoyed it. Hopefully I can get it done for the 2018 flying season. The only thing is that I am starting to question is my decision on putting in a DA100l in the plane. The predicted weight to be 27 to 28 lbs. it may be a little heavy for a 100, at present I am flying a 21 1/2 lbs extra with a DA 85 it’s ok but not outrageous. So I am pondering if I should put a DA120 in it . Does anyone have a suggestion. @ericrs can you tell what your plane weight is and how well does it pull out of a prop hang with a DA100. Or if you had to do it over would you go with a DA120. Thanks.
