Rusty 73
Xpress
So have you flown a DA100 ?
Okay then I know your into the 3D stuff and hanging off the prop and over heating your engine, that's cool if that's what you like .
But just saying the 120 is as smooth as the 100 is like comparing the DA170 to be as smooth as the DA150 and is not .
You can say it's airframe and what ever other thing you think would be a good or valid excess but it's not .
Do you balance your props before running them , even thought the factory says its balanced . This makes a huge difference , I just balance a new Mezjlik 28x10 and 28x12 , they required a couple of grams to proper balancing to eliminate and vibration from the prop .
Yes the DA120 isn't as smooth as the DA100 , just phone DA Dave or ask anyone of the techs them yourself ,they will set you straight .
