IMAC Scratch build Laser 200
Roger,
Wow, with the fantastic work you've done in the past I'll be sure to watch this thread in anticipation of a really unique giant!
BTW...any particular reason this one 'won't be' powered by gas?
Bill
certainly interesting but not being a fan of any 3D stuff, I will pass, but thanks for the confidence in me to be able to do this
Probably has to do more with precision than anything else. Having a retractable lower vertical is something nobody sees and will be truly unique. Would get a lot of attention if you did have any interest in it. Either way, your builds a re a joy to follow!!
These are drawings I am using
also will be using Bluebird 43A servos
Specifications
Torque At 6.0V 35.5 kg-cm / 493.1 oz-in
Torque At 7.4V 43.8 kg-cm / 608.4 oz-in
Torque At 8.4V 49.7 kg-cm / 690.3 oz-in
Speed At 6.0V 0.13 sec / 60°
Speed At 7.4V 0.11 sec / 60°
Speed At 8.4V 0.10 sec / 60°
Protection Mechanism
Soft Start Protection Soft start to neutral position.
Over Voltage Protection Over 9.0V drive the protection mode and 8.4V return to normal mode.
Low Voltage Protection Lower than 4.0V, drive the protection mode and 4.5V return to normal mode.
Locked Rotor Protection Stall in 5 sec, output torque goes down.
Temperature Protection Overheat 85 degree C, drive the protection mode and down 75 degree C
Power Supply
Operating Voltage Range 4.5V ~ 8.5V ( 4 ~ 6 Cell Ni-MH or 2S Li-Poly / 2S Li-Fe)
Standard Full Aluminum Servo
Control System Digital Controller / AD 12-Bits Resolution ( 4096 Steps )
Dead Band Width 0.001ms ( Default:1us)
Mechanical Specifications
Ball Bearing Dual
Gear Titanium Alloy Gears
Motor Premium Taiwan Brushless Motor
Horn / Gear Spline 25 Teeth ( Same as F-Type )
and this flight controller
http://boomarc.com/en/smart-bus-smo...qddo7_VaKt-UFiLJweUrsgigWkw1H3QL2MIveJK2D3C7s
Roger,
Bill
good question, but being I had purchased the large (100cc electric motor) for another project that didn't pan out, I will use in this one . but the way the airplane is built, I can always revert to gas later if I so please or can afford LOL
