They are quite cute and comfortable. I was disappointed that mine kept glitching out... turns out it was the "improved CNC gimbals" I put in. Put the old right stick back in and it's been great. I'm still having trouble coming from Futaba to this radio. I've been flying my TA horizons Cub around with it.
You EdgeTX guys, is there a way to reconfigure the format... or maybe I just need to reconfigure my brain. I just cannot seem to wrap my head around the layout easily... appears cryptic lol
That is pretty much why I bought it. I didn't want to try and program my Spektrum from scratch for a DLG. I couldn't find any ready made DLG templates for Spektrum. But I found this for Edge/Open TX https://rc-soar.com/edgetx/setups/dlg/index.php.
Nice find on the website. One thing that's cool with the pocket radio is that it has momentary switches that you can use for a launch mode. Since I'm right handed I keep that logic/momentary switch along with my flaps on my left hand so I can focus on catching and relaunching the glider with my right hand. Just a couple things to think about.
That is a big reason I went with the Pocket instead on the Boxer. The Boxer only has a momentary switch on the right side. Some people have gone threw the trouble of moving the momentary switch to the opposite side on the Boxer but it looked like more headache to do than I wanted.
"I just need to reconfigure my brain" Once you do it will become much easier. Developed a nice function the other day to control the starter in the current build, I wanted it to run for 5 seconds when the B switch is up and the F switch is pulled. The ignition is on when the B switch is centered or up and the choke activates when I pull and hold the F switch. The starter is controlled by a speed controller that needs low throttle to enable after it is powered up. Took a while but it works the way I want, I doubt you could do that in Futaba.
Nice, it's complicated but it is possible with a Futaba radio using similar logic in the "conditions" menu. Still convoluted!
Finally got my Radiomaster Pocket yesterday. I also ordered the 4 in 1 module so I can bind it with my Spektrum stuff. I’m really impressed with the build quality. Especially for the price. But I have a huge learning curve for sure. The Edge TX programming is tough for a non techie like myself. I think it’s going to work great with the DLG but not sure I’ll be using it for anything else. Spektrum has me spoiled. I just wish they made a radio more suited to DLG’s.
Mike,
Attached is a few documents that might help. These are OpenTX but apply to EdgeTX
  • LS_Tutorial_20190225.pdf
  • OpenTX Diagram - Inputs.pdf
  • OpenTX Diagram - Mixes.pdf
  • OpenTX Diagram - Output.pdf
