Send it to me before you do that.
I will say your first plane to learn Edgetx with being a dlg will test you as a dlg just has way more completed programming than a normal plane.
You read my mind lol! I’d already decided yesterday that it’s coming your way if I get totally discussed with it. I can’t even get all four servos to move. Best I’ve managed so far is 3 out of 4. And now one of those is on the wrong channel. I can’t get the elevator servo to budge. I bound it to an old foamie just to make sure the right side gimbal even worked. When I tried the elevator it operated the motor. Glad I didn’t have a prop on it. But at least I know the radio is sending signals.
BalsaDust
Might be easier to wipe that model out of the memory and start over.
Here there is a template you can save to your SD card and then open up in the radio and just reassign switches to match your preference. There is also a PDF setup guide for DLG's. very informative.
Look here Mike, templates for DLG in Open/EdgeTX
I have that file except the 4 servo version but for some reason I can’t get it to work on my radio. I’m going to try and download a different version of the edge firmware and try again.
