Fibertech
I have switch for the most part to Savox. The 40% and 35% are getting
SAVSV1270TG
HV CORELESS DIGITAL SERVO .11/486.1 STANDARD SIZE 7.4V
I use 7.4 set up
Single 1230 on rudder for me. Just make sure the horn in the rudder is something you trust and add at least one extra hinge down there since they tend to take a beating with a single. Even on my ARF's when I run a single rudder servo in tail I will add a hinge or two.
tylerzx9r
1270 for me, I urge you to do as Terry says, seen my hinges take a beating, needed one more at the bottom of the rudder.
Bipenut
Thanks everyone, I will go with the 1230 on my rudder. Terry I'm going to send you a PM about your control horns.
Spats
I am anticipating needing the tail weight anyhow due to the cans up front so I am using two in the rudder.
Spats
Prepped and primed the first coat on the cowl and canopy today. I started with 180 grit and then 220. I used a wax and grease remover before spraying. I will sand and spot fill tomorrow before spraying one last primer coat. I do not anticipate much need for to much spot putty as the glass work is very good on the cowl. The finish line is near I can feel it.
