Well thanks again I was thinking that I was over building again it is something I have to watch my sell. But yes I am going to come up with something completely new and hopefully light, but not as shown by them on the drawings that is just not doable. Hopefully something that is practical and suitable for the plane and the size of the canopy.@Snoopy1, I had the same concerns so I also made some changes. Firstly I added some 6.5mm sheet behind the front former of the the canopy to support the former and also to give something more for the dowels to bond into. It also provides more area for the transparency to glue and screw to. At the rear I added 9.5mm sheet for the same reason. I contoured it to match the fuselage and then tapered it to fit the canopy transparency onto. Down the sides I added 6.5 x 9.5 mm sheet and then sanded to the fuselage contour. This provided enough area all around to glue and screw the transparency on. I also added some spruce strips uderneath to strengthen the canopy floor, being careful to work around the structure within the fuselage. Hopefully the pictures give you a better sense (a picture being worth a thousand words, so four thousand in this case.
Let me know if it is not clear and I will try and clarify. I ended up with a strong canopy that I have never had an issue with.
Must say did some research today and did find out that several people lost the canopy off the plane several times.
