@AKNick will try to explain.
Take the tube and rub a very light layer of vaseline on it. Take note I said light just enough to look wet.
Then roll two wraps of saran-wrap on the tube as neat as possible. Ok what I am trying to explain is lay the tube down and then pull the Saran Wrap in the same direction as tube. Then roll the tube onto the Saran Wrap twice and cut off the rest.
Now use about 3 oz cloth it is not really that important how thick it is or how strong it is, just a tube so that you can slide the tube in easy without hitting the ribs. Cut the cloth 2 inches wide or buy 2 inch wide cloth with the edges sealed makes life a lot easier.
Ok hopefully I can explain this part clearly if not ask.
Ok before we start wrapping the tube we need masking tape and you will start 4 or 5 inch from one end so that when we are done we can hold onto the tube and pull the sleeve off.
Take the 2 inch wide cloth and set it up at an angle so that when it wraps around the the tube it overlaps 50%, the overlap needs to be one inch.
Ok 4 inches from the end of the tube at the correct angle use some masking tape and tape the cloth to the tube.
Ok wrap the tube all the way to the end and then use some masking tape to hold in place.
Note we will be be cutting 3 to 4 inches of either end to get a nice clean cut and good ends.
Now mix up some epoxy.
Use paint brush and brush just enough on to the cloth so that it looks wet and NO more. It must almost look dry.
When that is done pull out another length of Saran Wrap roll the tube into the Saran Wrap, 2 wraps again.
Now the important part, this makes the tube smooth and tight to the tube.
Take the masking tape and set it up in such a way that again it overlaps at about 50%.
Start at the exposed end of the tube. Tape to the tube and start wrapping all the way down down to the end. Hold the tape as tight as possible and straight no wrinkles and keep tight while wrapping all the way to the end.
Done. Let the sit for 24 hours.
Pull the masking tape of and Saran Wrap will come off as well. If the tube is wrapped nicely the tube will be smooth and flat.
Now pull the sleeve off the tube it will not be easy but it will come off. It has a tight fit which you want.
Ok now you have the sleeve with the Saran Wrap stuck on the inside.
Take a 12 inch long piece of wire with a hook on the end. Hook it to the Saran Wrap.
Hold the wire and rotate the tube around the wire. The Saran Wrap will now Wrap itself around the wire and pull out of the sleeve
Cut the ends off to the length you want and it is done. Try it, it will be a tight fit on the tube. If that is too tight you can add more wraps to the tube before wrapping with the cloth.
Hopefully this helps.
