Hmmm.... that's gives me something to think about... May just do a 60 single... be a little cleaner install
Limitless Aero sells the GP61 single cylinder engine...I've been thinking about putting one of these in my 89 FB Slick...it has a almost new DLE-55RA in it right now that pulls it around just great. Not sure if I should swap out the motor or put the GP-61 into a different (i.e. new) 50cc airframe, like a 50cc Extra from either Limitless Aero or RedWingRC...choice...choices.
My 89 slick
View attachment 19999View attachment 20000
Nachos Cheese Design
Yes, that is pearl purple.
Just getting around to updating my 89 Slick. Going to upgrade from 7955's to BLS172SV's and two R7008SB rx's. While I was looking it over I noticed that one of the aluminum L brackets that help hold the firewall to the motorbox was cracked. Spent the whole afternoon making two new ones and re-gluing the firewall back. In the first picture you can see the new one which is a little thicker and wider metal and the old cracked one that I had to heat up with a heat gun in the motorbox to get it to come loose because of it being glued in at the factory, in the process it got bent up a little. The original ones are really thin and very soft aluminum.
View attachment 21178 View attachment 21179
