Yowzilla
Well...I got side tracked with the fill tank...I could not resist the Secraft pump looks sweet and wanted to get it on the gas tank. The filter material is interesting and looks like the chips from all the machining. It looks like the stuff you want to keep from going in your engine.
That coil fuel line is a big pain to get on the larger nipple. Yes I said nipple. I had to use a heat gun to even have a chance at it. After burning my fingers while screaming, it got it as good as I could.
The blue line that comes with the tank has a flyer inside that mentions you must heat to get them on good. I guess the same material. On that,do you guys use safety wire on your fuel lines?
