Why not extend the servos leads and mount the esc in a place where it gets proper cooling?
On the telemetry, the short battery, telemetry, esc jumper has been done by others so you should be fine as long as it's short.
You can add a servo extension to the ESC just don't extend the battery leads.
I've heard as long as the battery leads, this includes leads on the ESC and the actual battery, should be no longer than 12''. So you can probably extend them a little but usually it's not a good idea. If you must extend the battery leads adding a CC Cap pack will help with the voltage ripple that occurs from making the leads longer.yea i thought i read that before, for some reason i woke up this morning and that was the first thing i thougt. must had a bad plane crash dream or somethingive read and studied so much in the past 6 month some things get scatterbrain'd. ive probably been lucky so far, because ive been flying with the jumper for a couple months now. will be fixin it this evening.
