Scale 50% Dalotel 165
working on the aluminum plates that will bolt in the middle of the box spar,
more work done on the metal plates to go into the spar and with the center section which I have received yesterday, you might have a better idea how it all goes together
Tseres
Forgues Research;9923 wrote: I have attached a drawing of the landing gear leg, in PDF, can anyone looking at it, tell me how I would do this to keep the bottom leg from rotating, its an oleo without the knee action so its all internal, , any suggestions would be appreciated
Thanks
Roger
I think you could make the lower leg of the oleo out of hex stock if you can figure out a way to machine the the hex into the upper part. That should keep it from rotating and should be strong. Of course there is the seals to consider but I think it could be done with screw in caps on the upper.
