Forgues-Research
Tseres;12056 wrote: I think you could make the lower leg of the oleo out of hex stock if you can figure out a way to machine the the hex into the upper part. That should keep it from rotating and should be strong. Of course there is the seals to consider but I think it could be done with screw in caps on the upper.
Ya that would probably work , but two things , as you said the receiving has to be machined, and also the bottom part which is exposed has to be round hmmmmm
