Yea I had the same thoughts promised wife that if I bought plane I would not start on it till after christmas just bought 2 other new planes a month ago well I ordered servos yesterday plane is done just waiting on servos and motor escMy Green MXS is here!!! I just got home and had to unbox it immediately! I am not going to be able to assemble it for a while because I am still working on gathering all of the components so I boxed it back up that is why I did not remove the protective plastic, yet. Anyways here is a shot of it on my floor.
Well if you didn't get the power combo i think the motrofly runs cooler than the torque but the torque has slightly more power. The motrofly is going to need a 100 amp ESC to run a 16'' prop and the torque only needs an 80 amp ESC. If you get the torque i'd recommend using a 15x8 or 16x7. They say you can use a 16x8 but there isn't really a noticeable difference between 16x7 and 16x8 in performance but you draw less amp with a 16x7. I've been running the torque since the plane came out and have put 160 flights on it so far and even though i can get the motor to heat up pretty good i've had zero issues with it. I mostly run 15x8s because that's what i like on my 60'' Extra but i throw a 16x7 on every now and then
Man i can't wait to take this thing to Lodi Huckfest :flyer:
The 100a esc is not necessary on the motrofly setup. I ran it on an airboss 80 with a 16x8 prop and at max on my bench test ran 71a, and I even set that down to about 65. I think Gary said he pulled 91a at one point, but until then I had never seen someone pull that high, I think 68-72 is where most people find theirs at wot.
Other than that you're description seemed spot on, maybe slightly more power, but it seems the motrofly runs much cooler and efficient. Either way you can't go wrong! Get what's in stock!
