Just wondering what batteries you use?
You have been around for a while you do ask the correct questions or I should say build many planes and seen it all.
Ok, batteries over the years I have had my share of difficulties with batteries, because of that I have purchased a full computer battery testing system.
My understanding of batteries and experience is as follows now all this only started when I started building planes bigger than 50cc and high powered digital servos.
1 First lesson large capacity batteries do not necessary work or solve voltage drops.
2. Do not use batteries labeled as RX batteries they have no punch and can have big voltage drops.
3. Use batteries that have at least 35C rating much better punch and a lot less voltage drop.
4. Always use 2 packs and no less than 3500mAh.
5. Use Power Box HD wire.
6. Keep good track of the IR on the individual cells of a battery pack. When one cell goes off the battery just loess it’s ability to push amps.
7. Do not use voltage regulators.
8. Run 2S LiPo at full voltage and use no less than XT 30 connectors.
When abiding to the 8. points above I believe I solved my voltage drop problems or I should say haven’t had problem since.
Ok Tony what are your thoughts of my experience.
