SteveT.
I have to be honest... it was reading through a bunch of your posts, as well as discussion here that lead me to my decision! So the gas prop in a smaller size (20") loads the prop better? Would running wood (vs. C.F.) in the PJN option be too much?
You can try it. This is the first and only prop I have tried on the motor, though, I may try a few others. When talking to Mike at Aero-model, I had asked about props and he suggested that as quite truthfully, the motor is designed to turn bigger props., but larger diameter props "can" cause torque problems, or prop strikes if you don't have the prop clearance.
SteveT.
