hone
Sweet Joe,
gotta ask, what did you do to the planes belly? Are you getting ready for a tuned pipe or something?
Daniel makes that bird sing.
I was planning on dropping a pipe in it but i'm having second thoughts. I had some cooling issues early on so i cut the tunnel out since i figured i was going to put a pipe in there anyways. I really don't have the time and resources to pull my engine, put it on a test stand, and get the right header length so I'll probably end up going with a pro flow canister instead and cover up some of the belly.
Daniel was saying you get quite a nice power increase out of a properly setup pipe though. Maybe i'll drop a DA35 in it if it can swing a 21'' prop to a good RPM. They can probably provide me with the correct header length for their engine taking away the trial and error that would probably end in error.
