hone
Nice job Joe!
As has been said previously, you could definitely lean out your low end mixture about 1/8 turn, maybe a hair more. It also sounds like it might be sagging a bit on the top end...so you could also richen the high speed mixture about 1/8 turn.
Normally, to tune a motor like this, I start at the recommended or factory settings, then go 1/4 turn richer (very rich). Then I let it idle and advance the throttle quickly. It should respond immediately. Then lean the low speed mixture 1/8 turn and try it again, noting how it responds. It should respond quickly but it will be running rough and burbling occasionally. Keep leaning the low speed mixture until it no longer responds well...it will bog when you advance the throttle. Then go back the other way, about 1/8 turn richer than where it bogs. The idea is that it's just rich enough to respond well.
Then set the high end...Go full throttle and take a RPM reading. Lean the high speed mixture 1/8 turn and take another reading. Keep doing this until you have reached peak RPM. Then richen the mixture barely enough to have the top RPM come down 100 rpm or so.
Thanks for the tips!
I'll have to write this all down for next time i go out to the field ahaha.
