Scooterpilot
I put two more flights on my EF with the VVRC 40cc. The motor's idle is spot on now and it's pulling better. I just ordered a 20X8 carbon prop for it. See how that will work next week.
I made me a carbon fiber landingear, it came out pretty nice i think, 100 gr, and stiffer than the aluminum one, we´ll see how it holds up.
Of course i vill share, its not that hard.
I started with making a plywood template, shaped as the landingear.
Used that to cut a foam block, than you have to cut it so it vill be 30mm at the top (where i mounts to the fuselage) and like 15mm at bottom.
Hold on, more to come, just have to do some other stuff in between.
Yes i know, the Picture is the wrong way, but you get the idea.![]()
