3D A Red Aero RC 108 Corvus is born!
Taildraggerrc
Bunky F. Knuckle;16631 wrote: Corvus #1 is done. Delivering to Pedro tomorrow, if he's cool with it. Final CG check with a 29x9 prop landed me slightly nose heavy to right on. Pix coming!
Looks good!
HurtinAlbertan;18818 wrote: I'm planning on fiberglassing the corners of my motor box also on the PAU Extra 300 I'm assembling. I was wondering was weight of cloth you used. I have .58 to 3 oz cloth. I was thinking of using 2 or 3 oz. Is just doing the corners enough, or should I do the whole motor box? Thanks in advance.
I believe that is 4oz..... Upper corners is.fine with a DA 120. I would.do the same if I put a, 3W 106 on the nose also.
Super08
Bunky F. Knuckle;18967 wrote: I believe that is 4oz..... Upper corners is.fine with a DA 120. I would.do the same if I put a, 3W 106 on the nose also.
....and that's no Bunk! ;)
Thanks for the reply. The heaviest cloth I had was 3 oz. I did all 4 corners, and also a 1.5" strip all the way around the front of the motor box.
