Xpress
How I read c rating to be is...It is the maximum safe continuous discharge rate of a pack. If you see 10C on your battery, it means it can be discharged at 10 times that pack's capacity.
You can think of C reading as the size of the pipe. The higher the C rating, the larger the diameter of pipe. Capacity is the size of the tank, and the motor is how powerful your water pump is.
I like TP packs because they're light, they last forever, and they seem to hold very close to their rated specs. Very consistent QC from batch to batch.
